Maze4 GPU clearence above card?
You can always switch it around so that most of the hardware is on the other side of the block...
IE, the screws are on the block side, and only the nuts are on the bracket side...
Just trim down the posts, and don't use the springs, they're not that helpful anyways.
Just be a little more careful when tightening it down.
