MAZE4 GPU block on an X800 Pro?
Dijonase
WIll the Maze4 GPU block fit an X800 Pro? The website says it will fit a 9800, but it doesn't mention the new line of cards. Hell, is anyone watercooling an X800 Pro with another block they'd recommend? Thanks!
Oh, and I'd like to try to keep the price around (or under) $40, which the Maze4 goes for.
AFAIK, the Maze4 will fit the X800 series. I could be wrong though. I am under the impression that the core area was the same design as the 9xxx series.
Yeah, I'm in the same boat. I think that it'll fit, but I want to be sure before I buy one. I also figured that I'd be able to get some opinions if there's a better block out there for the same price.
