Maze4 GPu block on an X800 Pro?
Dijonase
WIll the Maze4 GPU block fit an X800 Pro? The website says it will fit a 9800, but it doesn't mention the new line of cards. Hell, is anyone watercooling an X800 Pro with another block they'd recommend? Thanks!
EDIT: After thinking about it this probably belongs in the watercooling section. Ah well, I'll go ahead and put it in there. If a mod deems that it should be deleted then so be it.
