maze4 GPU - 4 way acylic backplate
malicious
I want to be able to use this thing on a 7600gt PCI-e
will it fit:
a)
b)
c)
d)
or all of the above?
"looks" like it will fit b,c,d
*edit on second hand looks like it will fit the xfx card too (just spotted the 4 holes)
have you emailed danger den on this? i bet they would measure for you
I think the four holes on card (a) are too close togethor; my FX 5900 has four holes as well, but they're too close togethor and I have to use the two hole hold down.
just to restate the question: I have no doubt that the block will fit, the question is can you use the 4 way acrylic backplate.
Ill ask the question...
why dont you email them yourself? If you had when you posted the question, you would have your answer by now, I have even given you a direct email in my post.
But,
Becuase im the helpful sort, Dano emailed me and said no, that will not work, you need to use the 2 hole bracket, not the 4 hold acrylic bracket. SO there ya go, you cant use it!
Chris
Cut and paste:
Chris,
The two hole mount is what is needed, not the 4 hole acrylic bracket.
Best Regards
Dan Stephens
dano@dangerden.com
www.dangerden.com
