Maze 4 Question
GFreeman9
Has anyone used Maze 4 on a GTX and how was your experience with it? I'm thinking about getting a GTX and I hope to put a maze 4 on it possibly.
well i'm somewhat new to the whole watercooling thing but I did put a maze4 on my x800 Pro and it dropped my temps about 20*C.
I have a 7800gtx and my maze4 should be here from dangerden on thursday I believe, so if you still want to know then I will tell ya
my gtx comes today in the mail - and i've already used my maze4 with success on my 6800GT - so i think it will work just as well.
the trick with the gtx is that the maze4 should perform just as good as on any other card, such as the 6800. the problem comes in when trying to use the nv-68 block - which cools the ram also... the 7800gtx has slightly thinner ram and the nv68 block doesn't fit and perform well on the 7800. The maze4 with some ram sinks should do just fine!!
