Maze 4 Mounting: 7800GT
gadnium
I was wondering if it was possible to mount the maze 4 so the barbs face the back of the card? The holes on the Maze 4 seem to make a perfect square, I have my radiator mounted on my sidepanel and no room to run tubing over the top of the card.
My card is getting fixed and getting this loop together is driving me nuts. If it comes down to not being able to change the orientation of the barbs then I'm gonna have to sandwich the sidepanel between the fans and radiator. Or just mount both on the outside...
The Maze 4 mounted on my 7800GT with the barbs facing the back of the card but I ran into problems with the chipset waterblock being in the way. So I externalling mounted my rad/fans on the sidpanel to make some room.
