kahunaking
- Dec 10, 2005
I have a DD maze 4 for my athlon 64. Is the maze 4 still a good block?
DFI Daishi said:no, it's not.
http://www.procooling.com/index.php?func=articles&disp=131
click a few modern blocks to compare.
that being said, it might or might not help your OC to go with a newer block.
Bbq said:Just wondering, is a RBX or a Whitewater better?
The Maze4 isn't a bad block. Just outdated.
werdnobi125 said:Get the TDX over the RBX, basically identical performance without the pain in the ass of having to plumb 3 tubes to it.
okay......now i didn't actually call it "bad" i just said it's not a good one. for me a "good" one is a block that is right up there in the pack of competition, but not one of the top three. the top three are the "excellent" ones. just the way that i choose to break things up.nobi125 said:From that site's own review of the DD TDX block (using the same graph):
"This graph is becoming less and less useful as I test waterblocks of widely differing design. The reader's instinct is to say the Maze4 is "a bad block" or that the Cascade is "best", but the dT vs. Flow rate graph only tells one half of the story, though."
"This typical user would see much less difference in performance than you'd expect by comparing all the blocks at an identical flow rate. I freely admit that I need to produce head loss vs. flow rate graphs for the waterblocks I test; this information would allow us to make "apples to apples" comparisons."
I wouldn't start calling the Maze 4 a bad block.
if it doesn't help you OC, then it's not worth it. no one can accurately predict that in advance. if nothing other than temps is holding you back now, than it'll help, but we can't know if that's the case or not.kahunaking said:Basicly would it be worth it for me to get a TDX even though i alredy have the maze4
probably the RBX, based on the hydraulic power vs performance plot that i mentioned above. however, the two blocks are within 0.01 C/W of each other, so there's no way to really know which is keeping you cooler on a live proc.Bbq said:So RBX > WW? I have both blocks, and I'm wondering which I should use.
