I am just embarking on my first W/cooled rig..... components are on thier way to me
Thinking ahead .... how easy it is to drain the system and add more components into the loop when the system is full with fluid ? is is necessary to drain the system every time you want to add components to the loop. if so, how do you do it ?
I will be using danger den components to cool the cpu and gpu using fill line rather than a reservoirs
sorry if this is a stupid question
