May not be the right place
Shalantas
Im not sure if this is the right place to get help but hard forum has never treated me wrong. Im attempting to shoot myself in to super geekness by making the halo 3 mark VI armor. Now i want to make a better tutorial then the one that was given to me and this is where i have a problem. Im attempting to make this film in widows movie maker to place on you tube but im having format issues. My operating system is windows XP home and it does have SP 3. I made sure i had the latest version of wmm. the camera im using is a JVC Everio. great picture with a big problem. When i put movie files into my computer they show up as a .MOD file so i simply decided to change the extension to .mpg. didnt work all i got was audio....no video, did some research and heard i should set it to avi just by changing the extension. did not work. Then decided to bust out the big guns. Cracked my knuckles and researched for....5...hours just to come across .mod is a mpeg-2 codec when wmm is only able to support mpeg-1 then to come across a format converter called creative 5. its supposed to be the best freeware....ever... not so much... aside from its lack of use friendliness it failed to make my .mod mpeg-2 into a wmm compatible extension mpeg-1. so basically i need help cause im bout to just go crazy with this and ive done all the research i could. o....and www.papajohns.org is useless as well. lol :p
Thx in advance.
