Stu55 said:which would you guys get?
Maxtor MaXLine III 300GB 7200RPM 16MB Cache SATA
http://www.newegg.com/Product/Product.asp?Item=N82E16822144186
or
Seagate Barracuda 250GB SATA 7200RPM 8MB Cache
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101571
JediK said:I would go with Maxtor. I have never had one drive fail me from them. Unlike WD where I have had to RMA a drive twice and different one went out this summer...
ivzk said:I'm quite on the opposite side from you. I've had 4 maxtor's fails so far, but the 5 WD drives that are, or were in my position are still running strong. Luck of the draw I guess.
From May of 2004? Overly influenced by the DeathStar 60GXP disaster. IBM was rightfully punished for allowing the 60GXP to have significant reliability issues because of a design defect. Also, Maxtor's "strong" showing in that poll was proably influenced by some bad design decisions they made. The last post in that thread was back in August. The storage landscape has changed quite a bit since then. All of the major HDD makers manufacture "reliable" products. A drive is much more likely to die from an environmental hazard than manufacturign defect or poor quality control nowadays.Susquehannock said:
Dark Ember said:
