Maxtor RMA Woes..
RabidRodents
So my 200 gig 7month maxtor is slowly deing (some pictures corrupt, OS wont boot off it, some files unreadable, etc), and I go to RMA it. They require an error code from a bootable dos program. The catch is, it doenst work on Nforce4, Nforce3, or raid connectors. Advice? I really have no idea what to do in this situation. It doenst make sense either...
They have an ISO that worked fine on my nF4 board. I'd be danged if I found it now though.
Also, I was able to RMA with them without a code before, i think.
Tell them that the disk isn't being recognized by the bios any more. Tell them it is really messed up and you lost all your valuable data. When I was going through my RMA, that was my problem and they just sent me a new one.
Great Advice ^_^
But for clarification, you do need a code:
"NOTE: SATA/ATA DRIVES ONLY. To receive an RMA you must have a PowerMax Diagnostic Code that indicates drive failure. To obtain this code, please download and run the PowerMax program. This procedure could save you the time and expense of exchanging a drive that is not defective."
"Note: PowerMax will identify drives connected to most Promise, CMD, and Highpoint ATA or SATA controllers. Powermax v 4.21 will not detect ATA or SATA hard disks connected to embedded or add in RAID controllers, NVIDIA Force 3, or Force 4 chipsets. If the hard disk is connected to an unsupported controllers, it will have to be moved to an alternate system or controller for diagnosis."
