My Maxtor HDD was recently not being detected by my promise sata controller. I figured out that the HDD was the problem after I saw a chip on the PCB blown and around the corner it was blown was some yellowish residue. So I know that the platters are perfectly fine and the chip that was blown might have done damage to some of the components around it.
I found the exact replacement PCB here.
As I have stated, the chip that was blown affected some of the surrounding components. Here's a picture of what it affected. I took pictures on my digital camera but I couldn't find the usb cable
I also want to know what I would be required of doing once I received this new PCB. In other words, would I have to solder it or just connect a cable to it, etc?
This hard drive is very important to me as it contains information that I have stored from the past two years. This data is not important enough though to spend hundreds of dollars sending it to a factory for repairation. Also, this HDD is out of warranty so RMA is out of the question. So because of the previous factors that were listed, I am not hesitating at all to proceed with swapping the PCB.
Thanks in advance.
-Alik4041
Thanks in advance.
-Alik4041
