Maxtor 320GB SATA only 79.99!
i'm lookin for a new hdd, how does this compare to seagates 7200.10?
Actually, p4 era, and yes I would need an adapter. I used to have PC with sata, had the works. Brush me up a little, what adapter should I get?
Has anyone had these for a period of time? I'm thinking about picking up a few for my new filer server and I want them to last a while.
Actually, if you call Newegg, their seagate's only have a 1 yr warranty. Kind of blows.
wow really, I've run my serial # (80gb laptop hd in sig from newegg) in seagate's site and it says 5 yr....hmmmm
EDIT: Ran my desktop's Seagate 7200.10 HD S/N (purchased just this week on NEWEGG) on their website and it states:
In Warranty: Expiration 24-Jan-2012
got it installed.. and it only reads at 150gb.. wtf?!
and yes its in store also..
Manufacturers say 1GB = 1,000,000,000 bytes (which is actually 1GiB)
Windows/BIOS says 1GB = 1,024,000,000 bytes (which is technically 1GB)
So that HD has 160,000,000,000 bytes which is technically 156.25 GB - then less after formatting.
Borderline false advertisement, except that they print a tiny little disclaimer about what I just said. So small it's hard to see without going blind.
Oh well, it's just like death and taxes: unavoidable without legislation (everything besides death :) )
Edit: for some reason, thought he had a 160GB drive, not 320 - oops - still, the math holds up ;)
Uh, no. A 320GB hd does not get detected as 150GB in windows. It's most likely a bios setting issue.
Yeah, I agree. You should see a lot more than 150Gb....I would say a 320GB HDD would be at least 300Gb after all that semantics bull crap.
Actually, it could get detected that way, prior to SP1 if you're running Windows XP.
Of course, that would indicate someone hasn't been patching for a long time, seeing as MS no longer supports pre-SP1 systems.
What does the bios say? If the bios says 150gb, then the drive is hosed (or the computer is WAY old). If the bios says 300+gb and windows says 150bg, then it's a windows problem.
So nice, I bit twice. I had to wait until I got my first order confirmation, and then I could place the order for the second. I'm tempted to get a third.
With any luck, these are actually the newer Maxtor manufactured by Seagate 7200.9 or 7200.10.
And for the record, newegg offers a 1year direct warranty on all the products they sell, outside of that year, you then have to fall back on the manufacturer's warranty. With Newegg, if it breaks, call them, rma, and get a full refund or a replacement. They are good like that and it makes it worth the extra 10 bucks or so.
Difficultone
