maxline III: how to enable ncq?
i installed this new hd and maxblast'd it (ghosted from old hd to new)
everything's working well but im curious, how do i know if ncq is enabled?
It depends. Microsoft's default IDE driver (used by the NVIDIA SATA controller if you did not install the NVIDIA IDE driver) does not support command queuing. Therefore, when you install the nForce4 drivers, you will have to also install the NVIDIA IDE driver in order to enable command queuing (which you can check after installing the NV IDE driver and rebooting by going into the Device Manager, and checking the properties for the NV SATA controller).
If you did not install the NV IDE driver, then command queuing is always disabled.
i installed the nvidia ide drivers, after i restarted, theres an icon that appeared in my task tray. "Safely remove hardware" how do i remove this icon?
