keithallenlaw
- Oct 4, 2008
Greetings.
I have a question about the Hero OC. I just purchased the new Hero,
the 4970K, 32gigs of GSkill ram, and the Samsung 850 Pro SSD.
I'm of a coarse doing a bench test before I install into my case.
So far things look good. All 32 gigs are posting. I don't have the
SSD connected yet. I'm just using the supplied CPU fan for bench
purpose but it will be wet when I'm done.
Okay, here's the problem/question. I just tried to do a small OC
and it wont accept it. Tried many of the bios options, manual and
some auto options. Nothing.
I'll have some time tonight to plug in a drive to see if this changes
anything, but I don't see how not having a drive effects OC'ing.
Maybe its the stock cpu cooler? The cpu bench idles at 42c.
Mobo @ 36c and the mosfets are @45c.
Update the bios? I'm using the 0904 bios that came with the
chipset. I did notice there are 2 newer updates. Try this?
Thanks for you time, and suggestions are much appreciated.
