Maximus V Extreme questions
TechLarry
RIP [H] Brother - June 1, 2022
I posted this in the review discussion, but it'll probably be seen better here:
I bought and installed one of these last night. I do have a question and I can't quite seem to understand the manual regarding the PCIe slots...
I am installing a single HD7970. I installed it in the second slot down because I felt it was a bit too close to the H80i Corsair Cooler installed in the Corsair 650D case.
I know the upper most slot is called the "Primary" Video slot.
Since I'm only using one card, is running it in the second slot down going to cost me any performance? I believe this is called slot 2A.
Do I need to make any other adjustments with the dips or BIOS to get the best performance with the single card setup?
One other thought.
That little mSata board is a pain in the ass. It took me forever to get the WiFi antennae's leads attached, and in fact I had to remove the MB (so I could remove the board holding screw) and mount the antennae leads with the card in my hand. Even then it was a royal pain in the ass.
When I put it back together I just left that damn screw out. If I want to later install the small SSD in there, I'd have to rip the entire machine apart again. Screw that. It seems to be secure enough without the screw.
I would have liked to see just a bit better engineering in this area.
Other than that, it rocks so far!
Now, hopefully all will power up properly when the Power Supply gets here
Oh, one other question. Running only a single HD7970, should I bother with the auxilliary Power Connectors on the board for the PCIe and backplane components? Should I connect them anyway just for the hell of it? PS will be a Corsair AX860i.
