Maximus IV Gene initial observation/warning
MassiveOverkill
If you're using a Thermalright/Cogage HS you may have to grind your mounting bracket down to clear capacitors:
The CPU socket is placed more inboard than my previous AM3 board. I can no longer remove/insert the motherboard plate with the heat sink installed:
I can only mount my Arrow in one direction since the solid caps get in the way of mounting the hold-down brackets in the other direction.......I could have ground it for clearance, but I'm not comfortable grinding the hold-down brackets for fear of weakening them (unlike the backplate mounting bracket):
The CPU hold-down lever: You may want to either put a rubber cap on the end of the lever or slightly bend the end of the lever tab up.......when you engage/disengage the lever, the end scratches the motherboard and hits a trace:
Maximus IV Gene deserves the honor of updating my signature, which I'll get around to sooner or later.
Asus socket layout and capacitor issue is starting to look like general issue for their LGA 1155 boards: http://hardforum.com/showthread.php?t=1618092 Link goes to a thread about the P8P67-WS Revolution and the poster asks:
Q: Then why in the hell would you solder a capacitor RIGHT NEXT TO THE CPU SOCKET that goes through the back of the board, effectively preventing any cooling that requires a backplate (virtually all aftermarket solutions) from being used with the motherboard?
I had no issue installing the backplate that came with my CoolIT ECO C240. Here's what it looks like (note this was with the P8P67-M Pro board, not my new M4GZ, though I think the board layouts are fairly similar):
Hmmm.... I am using the the TRUE version A with the Rev.B bolt-thru kit for Socket 1156 with this same board...
I did not notice the problem you mention... I have my system running 24/7 for the last 3 weeks without a hitch BTW.
Should I be worried now??? I don't feel like taking it apart :(
