Dec 20, 2008 #1 T tonyluu Gawd Joined Dec 20, 2008 Messages 613 Which one yields a higher FSB? Which one has a more enthusiast level BIOS? (lots and lots of configuration options in BIOS)
Dec 20, 2008 #2 G greens Limp Gawd Joined Apr 3, 2007 Messages 305 Well one is X48 and the other is P45. Do you plan to Crossfire in the future? Also, do you have a Dual Core or Quad Core processor? That has a factor in the higher FSB's. They're both ROG boards so I imagine they have the same amount of options in the BIOS.
Dec 20, 2008 #3 T tonyluu Gawd Joined Dec 20, 2008 Messages 613 Not all ROG boards have the most options, like the Rampage Extreme has much more tweak-able options in the BIOS than the standard Rampage This is just for further information, explain both FSB limitations for dual and quads
Dec 20, 2008 #4 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 BIOS options are probably similar, but I would expect the Maximus II to overclock better because it uses the P45 chipset, which is generally a better overclocker than the X48.
