x48 looks nice and all, but if it only supports ddr3 i'm not terribly interested, while it would be nice to have ddr3..it is so expensive right now
I believe in the early weeks of November.
*edit*: http://www.xbitlabs.com/news/chipsets/display/20071016090317.html
WTF is Intel doing!? The X38 JUST freaking came out! What are the new features of this chip?
The basic differences between the chipset Intel x48 and x38 is the official support to 1600 MHz system bus, corresponding frequency dividers, and also the possibility to exploit a pair of modules DDR 3-1600 with XMP technology and 1.8 v .
i was thinking of getting this board, but i recall people saying that the p35 asus boards (p5k series) were having issues with raptor hard drives. has this all been worked out on the maximus formula?
when is x48 due out?
Whats the difference between the formula and the plain P5E...I mean besides the hybrid water block on the northbridge?
My P5E have Maximus Formula printed on the PCB but covered with a strip of black sticker. I think the difference is the BIOS, LCD screen and some fancy stuff like LCD poster, onboard switches and a few fan connectors.
Do they P5E's have vdroop issues, or are they also resolved w/ newest BIOS updates as was stated in regards to the Maximus earlier in this thread?
My P5E also have this CPU Loadline in BIOS like the Maximus Formula
What is your NB temperature under load?
mis3,
......Having said that, my Northbridge is very warm, about 53 to 58 celcius or so using the ASUS software to measure. I haven't removed the Fusion waterblock to see if that lowers it, but only because I'm debating if I want to buy a watercooling setup now or wait a tiny bit, since other then the Northbridge being warm all is running great, and the NB being warm doesn't seem to be hurting a thing. Well that and my CPU heatsink is very large, I'd probably have to remove it to have clear access to at least one of the screws to the fusion waterblock. And yes, just the fusion block can be removed, it's held on by screws, the rest of the heatsink assembly would be in place if you pulled the fusion block. I'm sure you could then put in some other aftermarket heatsink that would fit in the space provided, if you could find one that fits in that square. Or I suppose you could contact ASUS and see if they would send you the P5E's block, from what I can see it just bolts on the same way......
I looked at board yesterday in the store. I saw the 4 screws holding the fusion block down but I did not see any separation (a line along the side) between the fusion block and the rest of the heatpipe. That's why I asked the question.
This link shows that the fusion block is integrated into the heat pipes assembly, cannot be changed. http://www.clunk.org.uk/forums/showpost.php?p=1330&postcount=164.
Looking at the 2 boards side-by-side, no much difference.
Features wise Maximus Formula has the 2nd LAN Port, onboard power and reset button, CLR-CMOS on the rear IO panel.
