After about one hour of P95 running on all cores my system simply BSODs.
The CPU has been tested 24+hrs P95 stable on a P5K-E and IP35 Pro @ 3200mhz (8x400) [1.25v]. The memory has been tested also.
At stock it doesn't BSOD. So it may appear that a higher FSB causes the instability.
P95 never even reports an error... just a BSOD. I've tried upping voltage. My temps are fine; the CPU doesn't load above 55C on the hottest core. I've lowered my OC to 3ghz (9x333) so that the memory is running way below stock... it BSODs.
CPU not a problem: check
Memory not a problem: check
I'm close to scrapping this board... any ideas?
