Maximus Extreme or ..... ?
MaXXimus
Im giving myself a headache trying to decide, I originally picked the Asus Maximus Extreme and the Corsair dominator DDR3 1800Mhz... now I know DDR3 is a waste since it doesnt give much of a performance boost for the price... but what other options do I have?
Reading up on the Maximus Extreme there are tons of people speaking such high praises and Im not seeing as much of that about other mobos. I was thinking maybe the Maximus Formula but not sure if it is CrossFire... NewEgg makes no refrence to it and one reviewer states there is no CrossFire Chip and then on TigerDirect it shows CrossFire as one of its features. Anyone know? If it does support it what would be my best option for memory... DDR2 1066? I see 1200Mhz but I swear I read about that stuff having issues.
The Maximus Formula supports Crossfire the same as the Maximus Extreme does. As for the memory, well the Maximus Formula can do 4x1066MHz modules depending on the RAM. I know it will do it with my OCZ Flex XLC PC2-9200 (1150MHz) modules with ease. Those modules use Micron D9 chips.
Ok what about this RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820145173
But I must ask this... What options and what performance differance will I be seeing when comparing Mobo and Memory - Maximus Extreme w/4GB DDR3 1800Mhz Dominator versus Maximus Formula w/4GB DDR2 CORSAIR XMS2 ?
Would like to see some real world info and not just comments in regards to how over priced the DDR3 is... frankly I could care less about price, Im more concerned about options and performance.
In the real world you would never be able to tell the difference between those two memory types..The nice thing about DDR2 based systems is that DDR2 motherboards tend to overclock better than their DDR3 counterparts. So you can actually potentially get more performance out of the DDR2 system right now. This is changing and the X48 DDR3 boards are getting much better but still haven't quite caught up to DDR2 based boards just yet.
Dan, do you feel the memory I picked is a good combination with the mobo? And what about your thoughts on the actual mobo?
Here are my thoughts on the Maximus Extreme and the Maximus Formula.The Corsair Dominator PC2-8500 modules are excellent especially for the price. While I can't guarantee that four sticks will work on the Maximus Formula, I have heard of the Dominator PC2-8500's working on quite a few boards in such a configuration.
Would you guys trust an Open Box SE version from NewEgg? I would tend to say no but cant hurt to ask. lol
It's a gamble dude. Some people get full boxes, others get scraps. Just ask yourself how many more hrs of work it's worth (probably only a few)...then the decision should be obvious haha.
I've never had a problem with open box stuff from Newegg. It works, but the packaging is a crapshoot.
I'd probably buy full retail on something that expensive personally.
Ok, guess I will pass on that deal then... sucks because I cant seem to find any kind of chipset blocks for the non SE. Maybe I need to just stick with the Maximus Extreme and DDR3, least that has the water cooling block already on it.
Does water cooling the NB really matter that much? You could get something like an HR-05 and do a great job cooling the NB without adding stuff to your loop.
No actually it doesn't. It does lower temperatures some but it doesn't seem to impact overclockability in my experience.
I just want to have the loops for it to add to the overall look. There must be something out there right? I see all these blocks for other mobos and include CPU, NB, SB and even MOSFET and I cant find nadda for the Formula
Trust me adding the north bridge to the loop only makes it a huge pain in the ass when you have to take the machine apart or replace the board.
Yeah I really don't understand why people turn their sleek watercooling systems into a huge rats nest with 8000 tubes going every which way and waterblocks on half their mobo. Probably gets them 50mhz in final core speed max versus just cooling the CPU itself. Hell, if they just stick it in the loop with their CPU they may actually reduce the cooling their CPU gets, _harming_ their overclock.
Also I second Dan's thoughts here. Forget watercooling the chipset. Also, avoid the DDR3 if possible, right now its performance is not really any better than DDR2, and if you're overclocking, you'll probably end up with _less_ overclocking potential.
I know you said you don't care about the price, but why pay more money for less performance? Doesn't make sense to me.
QUOTE]
I think to each is own. I don't have any kind of before or after comparisons with a watercooled NB as I started it on water. It doesn't have to be a rat's nest though. :)
This is my daily clock setup of 4050Mhz. Everything is very fast and responsive. It is 12hrs stable on P95v253.
To the OP, I really enjoy the Maximus Extreme along with DDR3 memory. Do what you feel comfortable with and what will make you happy after the fact.
Just my .02
That actually doesn't half bad. Good job keeping it clean.
Ok so lets say I stick with the Maximus Formula, what other then CPU and GPU's would you water cool... or would you say to only water cool these and everything else on air? Anyone point me in the direction of a CPU water block for the Formula?
Now what do you suggest for air cooling... again... money no option and take into account the water cooling loops. Also, do you recommend using any chipsinks on the board? Basically I will take any suggestion thrown at me to keep the mobo as cool as humanly possible.
Stick a fan on your RAM! Look at Vegasr's pictures above, he has a good sized fan cooling his RAM. This can be really important because some RAM runs pretty hot, and some RAM likes to die at high temps. (Crucial Ballistix for one, while awesome, is quite toasty.)
Other than that, just keep some half-decent airflow through your case. With watercooled CPU and GPU you don't need a bunch of fans.
Vegasr thats really sweet... clean cut all the way. As for the Maximus Extreme... I did some extra reading up and Im leaning towards not wanting it. If I can get the same performance out of the Formula + DDR2 1066Mhz and spend $700 less (figured it out) then its almost like a no brainer.
Im trying to way my options here. I will have a 1x120.3 rad and 2x120.2, plan was to have each of my 3870 X2's on seperate 120.2 loops or just combine both 120.2's and have them on that... then have my CPU on the 120.3 and since the CPU is on such a big rad, I figured it was a waste to not add something else to it... thats why I was thinking NB, SB and MOSFET on there with the CPU.
Honestly I dont know what the best setup it... this all new to me.
Thanks MaX and NKD.
I agree about the cost, only reason I went the DDR3 route is I found a GREAT price on the SuperTalent ProjectX 1800.
Good luck with your builld.
