Maximum RAM for old Intel BX mobo?
Rob94hawk
Can I use 2x512MB dimms in my bx mobo using WinXP? Or will the board have issues? Thanx. Rob
I think you can reach 1GB but you can't use anything larger than 256MB DIMMs if I am not mistaken. So you would need 4 256MB chips.
It also depends on the maximum L2 cachability of your CPU. Most of the earlier PIIs and PIIIs have a maximum L2 cachable RAM limit of only 512MB total. If you have an original 233 to 300MHz 0.35-micron Klamath PII, or any of the common steppings of 0.25-micron Deschutes PIIs or Katmai PIIIs (all of which have 512K of off-chip but in-module L2 cache running at half the core clock speed), don't put more than 512MB of memory in your BX-chipset-based system; otherwise, your system may run slower. But all of the Coppermine PIIIs and Mendocino and Coppermine128 Celerons can cache up to 4GB of RAM, so you can use up to the maximum amount of memory that your BX-based mobo allows (768MB for a 3 DIMM mobo, 1GB for a 4 DIMM mobo).
And nope; the BX-chipset-based motherboards cannot support 512MB modules at all - those modules will be recognized as 256MB modules, or you'll get data corruption if you attempt to boot up with those 512MB modules, or (in the worst cases) your system won't even boot up at all.
Yeah I agree. That makes sense. I wasn't aware of a cacheability limit of the CPU however. Since the CPU's themselves have a large addressability range. But the memory thing is about right.
While most BX boards will take up to a 256MB stick in each slot, I do have 2 machines that will only accept up to 128MB stick, must be a bios thing
And not only that, but some BX boards that accept 256MB sticks require that those 256MB sticks be registered DIMMs.
Thanx. Since I already have a 256MB module in there I guess I can go to 768MB since there are only 3 memory slots.
I also have a 1.4Ghz Tually in there but from what you guys are telling me it is dependent on the chipset and not the CPU. Right?
