max voltage?e6850
madmax30d
im trying to o/c my e6850 on my 680i sli motherboard. Im using tuniq tower
So far its running at 1.4v, , 400FSB, 3.6ghz, at 40c idle(in bios)
Im wondering what the max voltage i should be using?
Im trying to see if i can get to 4ghz
whats thee stock volts, just out of curriosity?
1.55v is what intel say for the max, though recomending that i wouldnt.
i would keep under 60 degrees load, i cant tell with ure temps, unless i have load temps.
