Max recommended temperature for a Qx9650?
under 60°C at full load, according to some intel whitepaper.
Generally speaking, it's best to have full load temp below 60C. If it gets to about, or just over 60C, then I would recommend improving the cooling system.
Technically, your CPU can go as high as 95C. Realistically, I would suggest keeping it under 70-75C. Temperatures over 60C, although not ideal, are also not at all harmful to the CPU, so you shouldn't worry if you end up in that range.
~60 under full load in OCCT or something would be a decent goal. If it is a little higher it gives you something to work for. You should be able to hit 4ghz with a good cooler and stay in that range.
