MAX OC you have done?
zmgraphix
My max so far has been 2700 on my 2800+ and still no cmos that needs to be reset :)
I went to 3.3 last night...I guess I got a BSOD because my computer shut down without warning.
see sig...these settings have been running prime stable for 15 hours and counting!!!
3.65 on a 2.8C 14 X 261FSB 1.7V
Currently 3.42ghz 2.4C @ 286fsb 1:1 with my ram. :D Wish I had a better board. AI7 doesn't do memory bandwidth very well.
2346 on my Barton 2500+ @ 1.8V
204X11.5 ... can't seem to boot with my mult any higher than 11.5... anybody else see this?
p4: (asus p4p800/koolance)
2.2 @ 2.53 stock volts
2.6 @ 3.5 1.75v
2.8 @ 3.3 stock voltages
3.0 @ 3.7 1.8v
AMD: (shuttle sn45g)
1800+ @ 1.9ghz
2200+ @ 2.0ghz
2500+ unlocked @ 2425mhz 1.7v
2500+ locked @ 2.5ghz 1.75v
Palm V:
16mhz @ 29mhz stock voltages
P4 3.0 @ 3.75 @ 1.8V. Booted into windows, ran CPU-Z, tried playing a game and the intel throttling came on. Temps were around 160F. I was using a Swiftech MCX4000 with a 92mm tornado. I was drunk that night. There's no way I would potentially kill my proc when sober :D
my max was pro speeds on my 9800(havnt oc'd my ath. 2200+ as it 1.dosnt have a reputation for good ocing,
2. im running a semi-stock cooler(based on stock desing with coper slug in base). i also dont have good ocing mobo or ram :p my next set up wont be much better(k8v with a.64 2800+)
i'd do the same, but I have limiting RAM :p
I have a pretty good board though, IC7-Max 3
2390 Mhz @ 1.675v stable for ~24 hours doing anything i want. stupid msi board doesnt go up to 2.8 vdimm, core voltage limited to 1.8 with board overvolting like hell, and im pretty sure that the northbridge voltage isnt to high. if i wasnt getting a 9800 pro, id go get a dfi infinity.
Just started with my Vapo unit...
2200+ @ 2.4 GHz with Stock Cooling, and Stock Voltages... No case fans :D ... Temps are: 45-50C(ish) Max load, 36-38C Idle... Unfortunetly it out-performs my 2500+... and that sucks.. (2200 in family computer... and I like to stay on my computer, even though i built them both)
