Max Height CPU Cooler/HSF in 19" 4U?
hotzen
Hello guys, short question:
What is the max height of a CPU Cooler in a 19" 4U chassis? (say Norco RPC-450 like)
About 140mm, or even less?
1U = 44,5mm in height so 4 units = 178mm, which should be outer dimensions on the front panel. Deduct whatever few mm of casing difference and mobo standoffs. Depends on the chassis really and there's no standard height for standoffs. I'd say ~30mm off. 140mm could fit with some luck.
Another thing to note is that the motherboard is not flat with the bottom of the case. I was unable to fit a thermalright ultra 120 extreme (160mm high) in the norco. It stuck out about 15mm from the bottom of the case top. 140mm should fit.
I ended up going with a corsair h50 I picked up cheap and mounted it to one of the fan holes in the middle.
