- Feb 16, 2003
So the company I'm at has had poor management of their data storage structure. There are directories upon directories upon directories and long file character names that are reaching the Windows character limit. This is causing problems with permissions being changed (another story), as well as trying to clean up data like organizing the structure. It's gotten bad enough that I can't just go and rename the final file because of the character limit.
Is there any tool, application, or easy way to fix naming or at least move the files without renaming everything at this time?
For example, this would be one of the directory structures:
SHARE: PROJECTS
Dir: 2019 - Projects in progress
Sub Dir: 2019 - Our Company Name -Projects - R&D In Progress
Sub Sub Dir: 2019 - Our Company Abreviation RD Projects StupidClientnameCo
Sub Sub Sub Dir: StupidClientnameCo
Sub Sub Sub Sub Dir: 2019 - Design StupidClientnameCo
FileName: README - Bob, check the switch before you leave the inspections facility to disable the testing cooling system.txt
Contents: README - Bob, check the switch before you leave the inspections facility to disable the testing cooling system.txt
In some cases, there are shortcuts created going to a directory in the same directory that contains NO OTHER sub directories. So I think it's a black hole of directories.
Also:
Directories with parenthesis around things.... *sigh*
SHARE: PROJECTS
Also:
