Ok, so I have thi nice little HP case, circa 1992, that my sister gave me after I built her a newer machine. Perfect candidate for some cutting and painting and I decided I'm going to move my windows machine to it and switch whatever hardware is left over to Linux as my main desktop, with the windows box as my gaming machine.
By the time I have finished with the box I will have a 2.8C, 1 GB of matched DDR, a 9800xt and possibly a DVD/CDR combo. The case itself is basically a standard mATX case (downsized ATX) exept that it is as wide as my ATX cases (most of the ones I have seen seem less wide) so I'm planning on putting a fullsize PSU in it.
Airflow will not be a problem, 1 92mm front, 2 80mm side, 2 80mm top, 1 80mm rear. There will be only one open external drive bay while will be whatever optical drive I end up putting in it. ZGoing to mount the HDD in one of the no longer external 5.25 drive bays so I can pad it and the top of the bezel will likely be getting the power switch, fan switches, and power switch.
So basically, my question is, which mATX board should go in this thing? I would liek to have some overclocking ability since I will be putting the best of my hardware in it, and while I know I likely won't get as much out of a mATX board, I'm thoroughly fed up with Windows and the only thing it offers me anymore is my games.
I've spent a great deal of time trawling through the internet hoping someone had done some wierd roundup on mATX boards, but have yet to find anything reliable. Any thoughts?
