It seems many threads all over the internet has/had/have asked this same question all over.
was tweaktown's review really truthful ? sadly.. it wasn't.
Difference between 16x PCI-e vs 8x PCI-e in CrossFire/SLI ?
Answer:
Here is why.
PCI-e 2.0 16X = 8GB/s total bandwidth
PCI-e 2.0 8X = 4GB/s total bandwidth
ATI:
HD 3870 = 1125mhz (dual piped - 2.2 GB/s data rate) = 2.2 GB/s total data rate
HD 4650 = 500mhz (dual piped - 1 GB/s data rate) = 1 GB/s total data rate
HD 4670 = 1000mhz (single piped - 2 GB/s data rate) = 2 GB/s total data rate
HD 4770 = 800mhz (quad piped - 3.6 GB/s data rate) = 3.6 GB/s total data rate
HD 4830 = 900mhz = (dual piped - 1.9 GB/s data rate) = 1.9 GB/s total data rate
HD 4850 = 993mhz (dual piped - 1.9 GB/s data rate) = 1.9 GB/s total data rate
HD 4850 X2 = 993mhz (dual piped - 1.9 GB/s data rate)(times 2) = 3.8 GB/s total data rate
HD 4870 = 900mhz (quad piped - 3.6 GB/s data rate) = 3.6 GB/s total data rate
HD 4890 = 975mhz (quad piped - 3.9 GB/s data rate) = 3.9 GB/s total data rate
HD 4870 X2 = 900mhz (quad piped - 3.6 GB/s data rate)(times 2) = 7.2 GB/s total data rate
So as you can see, the 4870 X2 will be hurt in an 8X condition and why the 3870, 4650, 4670, 4770, 4830, 4850, 4870, 4890, and 4850 X2 will not be hurt in performance at all.
Nvidia:
8800 Ultra = 1080mhz (dual piped - 2.1 GB/s data rate) = 2.1 GB/s data rate
9600 GT = 900mhz (dual piped - 1.8 GB/s data rate) = 1.8 GB/s total data rate
9800 GTX = 1100mhz (dual piped - 2.2 GB/s data rate) = 2.2 GB/s total data rate
GTS 250 = 1100mhz (dual piped - 2.2 GB/s data rate) = 2.2 GB/s total data rate
GTX 260 216 = 999mhz (dual piped - 1.9 GB/s data rate) = 1.9 GB/s total data rate
GTX 275 = 1134mhz (dual piped - 2.2 GB/s data rate) = 2.2 GB/s total data rate
GTX 280 = 1053mhz (dual piped - 2.1 GB/s data rate) = 2.1 GB/s data rate
GTX 285 = 1242mhz (dual piped - 2.4 GB/s data rate) = 2.4 GB/s data rate
GTX 295 = 999mhz (dual piped - 1.9 GB/s data rate)(times 2) = 3.8 GB/s total data rate
GTX 285X2 = 1242mhz (dual piped - 2.4 GB/s data rate)(times 2) = 4.8 GB/s data rate
So as you can see, the GTX285 X2 will be hurt in an 8X condition and why the 8800, 9600, 9800, 250, 260, 280, 275, 285 & 295 will not be hurt in performance at all.
Check this pic:
This should be a clear message to anyone wanting to do multi-gpu setup's, people with PCI-e 2.0 @ 16x-16x-8x or 16x-8x-8x or even 8x-8x-8x bandwidth should have no bottle neck for any single gpu cards in the market, aside from the double gpu cards like 4870x2, and incoming GTX285x2.
a quick example:
Which is better performance in fps/gaming, 16x-8x-8x w/ PCI-e 2.0 motherboard vs 16x-16x-16x w/ PCI-e 2.0 motherboard vs 8x-8x-8x w/ PCI-e 2.0 motherboard:
Code:
1x 4870 1GB @ 16x slot
1x 4870 1GB @ 8x slot
vs
vs
Winner:
Draw, no difference in fps. Although some 16x-16x-16x boards with n200 chipset's has fps drops in games which is reviewed many times but no drops in benchmarking (3dmarks,vantage). If your board is PCI-e 1.0 then that would be a huge difference![]()
cool found this http://www.newegg.com/Product/Produc...82E16813131371 in
http://www.hardforum.com/showthread.php?t=900405 im sold ordered one now
ASUS Maximus III GENE LGA 1156 Intel P55 Micro ATX Intel Motherboard is the board im going with... sucks that theres no am3 sli support
Wow...a negligible performance deficit versus a marked improvement in heat and power consumption at a lower price (factoring in motherboard costs).Dual GPU for X58 vs P55 is not a HUGE issue (at least with the current GPU)
Even Tweaktown numbers are not usefull as they are more "theorycrafting" than anything..
Anandtechs did a great test, and came up with 3-7% lower performance on average with for the P55 using Dual 5870...
http://www.anandtech.com/mb/showdoc.aspx?i=3649
Bad link.
