MATX power supply help
KingTKS
I have a matx case and i need a power supply and here are the items in the computer
ATI radeon 9800 pro 128mb
ledtek winfast 2000 xp
sony dual layer dvd burner
2 Western digital IDE hard drives 120gig special edition on raid 0
and i think the motherboard i will buy for it is the BIOSTAR "M7NCG 400" nForce2 IGP Motherboard for AMD Socket A CPU -RETAIL
with a barton 2500 overclocked at 2.2 GHZ
I dont know anything about power supplies so i need help from everyone to tell me if it is even possible to do this with a matx power supply
the best i found is this enermax
ENERMAX 270W Power supply for Intel P4 and AMD XP, Model "EG285SX-VB(W)SFM" -RETAIL
Model# EG285SX-VB(W)SFM
Item # N82E16817103453
Specifications:
Type: MicroATX
Maximum Power: 270W
PFC: Active PFC
Voltage Rating: (G): 180V~264V (W): 90V~264V
Hold-up Time: 16ms at 115VAC or 230VAC, full load
Efficiency: 70% min.at 230VAC
Over Voltage Protection: +5V: 5.5V~7.0V+3.3V: 3.7V~4.3V +12V:13.4~15.6V
Overload Protection: 110%~160% of max load
Input Frequency Range: 47-63Hz
Input Current: 6A/3A
MTBF: 100K hours at 25ºC
Approvals: UL cUL TUV DEMKO NEMKO SEMKO FIMKO
if this is good tell me or if you have a better suggestion that would be great.
i just wish they made a massive 600 watt matx power supply :)
thanks for your help
also if you recommend a better motherboard that would be appreciated too (can't find one with raid)
last question, what does pfc mean? some power supply term
Definitly the Enermax 285, 20a on the 12v is beefy for such a little guy! Lol, that's more than my old-school Enermax 300
