MATX mobo
KingTKS
ok i bought the biostar m7ncg 400 because everyone said it dominated for matx so i got it and it didn't work for some reason. so instead of risking getting another i decided to try a different motherboard. but i hear so many bad things about all of them and i was wondering which one you guys think sounds best for me.
I NEED the following:
Micro ATX
will support my Barton 2500
Onboard sound
NIC
Ultra DMA 133
AGP 8x (for radeon 9800 pro)
2PCI or more
Nforce2 (for dual ddr)
any suggestions?
also i would like to overclock my cpu at 200fsb and 10 multiplyer = 2.0GHZ
Micro ATX
Onboard sound
NIC
Ultra DMA 133
2PCI or more
any suggestions?
Well believe it or not, you've run out of choices. That biostar is the only matx socket A mobo thats equipped for high oc's. A couple of choices used to exist but they can only be found on ebay nowadays. One of them is the original M7NCG Matx MCP-T, the 2nd and 3rd revs had full oc options. All the other Via/Nvidia Matx solutions all lack multi adjustments which effectively rule them out (unless your willing to do a pin mod). Another thing to note: your requirement of running 8X agp, you might want try running 4x agp at first since theirs virtually no performance hit and runs more stable on that platform. Good luck in your endeavor either way.
http://www.asrock.com.tw/product/product_k7s41.htm
Has ok OC options, and good bios support.
" 1. ASRock U-COP
2. Hybrid Booster - a safe overclocking feature
3. FSB 400/333/266/200, DDR 400/333/266
4. Real 256E 3D Gfx. Max. 64MB
5. 1 slot for AGP 8X/4X 1.5V
6. ASROCK I/O - 4 ports default on rear panel + 2 ports upgrade via header.
7. ATA 133 supported
8. On board default 10/100 LAN and 5.1-Ch Audio.
9. Multi-languages Quick Installation Guide.
10. Bundle CD includes PC-cillin 2002, ASRock PC DIY Live Demo, Audio Player, etc.
There was a link on the main [H] website a while back to a review of that board.
I have a system here at the office that runs on an Asus A7N8X-VM/400 and a Barton 2500+. I know that the board will support a 400 FSB, though the memory is still limited to a 333 by the chipset.
That ASRock based on the SiS is interesting. Hadn't heard of that one... Wonder what it's voltage options are... It only has 2 pci slots though and if you use a VGA Silencer on your video card, you're stuck with 1.
Epox 8RGMI in my sig has full range of overclocking options. It's the only other nForce2 option I know of that has multi control. I went through at least 6 Biostar M7NCG that mysteriously died on me for whatever reason (crappy PSU, case shorts, quality control problems?). I never had a chance to really overclock them, but from another user who had two said 200 was the max to hope from them even without using onboard vid.
Pros:
There's alot to recommend about the 8RGMI. Feature wise the sound on it, though a software solution, sounds very good and offers an excellent set of audio controls.
Board also gives you full health status at boot, which is an awesome feature.
Now having used Epox tech's support for a seemingly difficult question, I will say their tech support is also excellent. The tech was intuitive, guessing at things I might have done, responded within a day and he still had the answer nailed in his first reply.
The major plus is that the 5v connector on the board made my rails about a hundred times more stable than the Biostars.
Lastly the CPU socket is farther away from the input ports, so if you are using an ARIA and a relatively narrow aftermarket cooler (ALX-800), this means that it won't be under the power supply and you could theoretically switch it out. At the very least, is should increase the amount of options for heatsinks you can use.
Cons:
I have seen some users say they've hit 230fsb on the board, but I can tell you only that mine requires 1.8v to be fully stable @ 200fsb. The passive cooling on the northbridge is a problem (it gets hot) and I think if you stuck an NB-1 on there it would make a world of difference and 220 is within reason.
Compared to the Biostar, there are only 2 PCI slots. However, the bonus is that the way they are placed, they skip a spot after the AGP port, so if you use a VGA Silencer, you would be losing it anyway on the Biostar.
The CMOS reset jumper is sandwiched between the first PCI slot and the AGP port, so if you have any PCI cards installed, it requires removing them. This is a major PITA and I cannot think of many more annoying places to put this. I suggest figuring out how well it overclocks first before installing peripheral cards.
Overall there are no perfect mATX boards, but between the two choices, I am extremely happy with this Epox.
Interesting side note, Epox discontinued this version, replacing it with the 8RGM3I, which has been stripped of the overclocking options. That's why you never hear of it.
Mwave was where I bought mine about a month ago, the cheapest place that had it.
