mATX case help.
bbbrad
Looking for something a little larger and quieter than my SG05. I have been looking at the Fractal Design Define Mini but it has 2 flaws. First I would like to be able to remove both HDD cages but the bottom one isn't removable and the second problem which is a deal breaker for me is there are no removable dust filters for the front fans (they are attached to the fans).
I have also looked at the Corsair 330r which looks comparable to the Define Mini but bigger I think. It also has some downfalls lacking rubber grommets on the cable management holes and no tie-downs for cable management.
Are there anything other quiet mATX or larger mITX cases that I should look at?
Not bad but it would probably still be louder than I would prefer with the 92mm fans, lack of cable management options and sound dampening.
