tj08-e
it fits even 200mm rad and two fansThat case with a 180mm rad would be a interesting combo. Though from the looks of things it too won't be able to fit a corsair hx750
Shoot at this point I'm about to just say screw it and stick with an ATX case for watercooling. Unless anyone has anymore cool ideas?
That picture looks a bit different in the front panel then the ones I've seen of that case.You can WC The TJ07 much easier than the TJ08. I finally decided to try the TJ07 and see if a 2x120mm rad would fit, since after a lot of searching all I found were people asking if H100's would fit. I can finally say they do, kinda. You give up a lot when you try to stick a rad up front. Mainly all the internal drive bays, and one of the 5.25" bays.
http://airepoweraviation.com/pictures/TJ07wc.jpg
The problem with getting a 120mm rad to fit easily is the 2.5" SSD mounts on the bottom of the case. That part of the case is elevated from the rest of the bottom of the case, and the 2.5" mounting points are recessed from the bottom, raising them up inside the case even further (see pic).
http://airepoweraviation.com/pictures/case_interior_top.jpg
The metal has enough give (you only need about 1.5mm for the H100's radiator) to where you can force it to fit. I chose to mush the screw hole that was in the way to get the space I needed.
Interesting, That case does look pretty slick too. just not a big fan of the fake aluminum look front panel...It's a little bigger but...
Fractal Design Arc Mini, probably the easiest mATX case for a custom loop or H100.
WOW! look at how much has been CRAMMED into that small spaceit fits even 200mm rad and two fans
http://cdn.overclock.net/a/a5/600x450px-LL-a5e90418_12292011352.jpeg
you can get psu extender to fit any psu in it, but i'd just get some shorter psu (there are even >1000w ones that would fit in)
P.S. what do you think of the Maximus V board?
WOW! look at how much has been CRAMMED into that small space![]()
