Matte Black & White
OP20
600T fits a 400mm x 200mm radiator quite nicely :)
four 200mm fans & six 120mm fans
Water cooling with Mayehm pastel white
2 Evga hydro coppers on their 670 ftw's
Laser cutting all the acrylic panels.
No LED lighting :) Mostly a matte black & matte white build!
Where did you purchase that radiator from? If you don't mind my asking?
I've been thinking of doing this with my NZXT Phantom case. Your build is looking very sweet!
Any sponsors? Thats a very sick looking front! I have he same case and im about to put a window in. Are you putting the grills in the front back on?
No sponsors. I am putting the grill back on the front. The side panel is going to be 100% acrylic so youll be able to see everything inside.
Sounds like its going to be sweet when its done, Some one should sponsor this guy.
I'm not putting a drive in my next build, you hardly ever need one after the initial software bombardment
