math problem reg volts amps on fan
exe
I have two fans in a monitor that I want to replace. I'm replacing it to get a slower spinning quieter fan, so replacing with a bigger fan is not an issue. The problem is, I don't know what the volt and amps mean, so I'm not sure what replacements I can try to find.
Old fan spec:
Sanyo Denki 109P0624W602
24v .07A 1.68watts
60mm x60mm. 20mm thick
4200rpm 31dBA 15CFM
<http://sanyodb.colle.co.jp/product_db_e/coolingfan/dcfan/cooling_dcfa
n.html>
My questions are:
Do I have to get a 24volt fan?
Can I use any fan rated higher than 70mA?
Should I know and how do I know what the 3 wire leads do, or are they
standard with other 3 pin fans?
I found a Panaflo 92mm fan, can I use it as a replacement? The specs:
FBA09A24M Voltage Rating 24V
Operation Voltage 14—27.6V
Rated Current 110mA
Rated Input 2.64W
Nominal Speed 2450RPM
Max Air Flow 48.0CFM
Noise 30.0dBA
Connector 3pin
Any links to where I might find a 24v fan would be appreciated. Thanks for the input.
