Master and slave drives, how do they work now?
  • Thread starter Deleted member 108676
  • Start date
D
Guest
I know in the past you had jumpers, but it doesn't appear there are such things anymore. I need a new internal hard drive to save stuff on. It'll be going into an existing comptuer. Do I just put it in, plug it up and let windows do its thing?
Also, whats the max size drive windows 8 will see?
I use to know all these things...I've been away from it so long I don't know these things any more.
That died a LONG time ago, and was when you plugged multiple drives into a UDMA cable. With SATA just plug them in until you have no more ports, they will show as additional drives automatically in windows.
You are thinking of PATA or IDE drives which had a Master and a Slave. They are technologically obsolete by several years. Maybe your computer has SATA drives.
