Wes Manthooth
- Jun 9, 2005
alright, sigh, i have a problom...my computer loads the os and gets to desktop, goes to some blue screen then restarts. it is not the BSOD, it is the screen with the physical memorey dump. after much reseash and 3 times of relaoding the OS, i found out this problom is normal cuased by bad memoery. so this afternoon i play the process of emlination game and think i found the bad stick, come back tonight after partice and find that with the "good" stick same problom, so i am like fuck, 2 bad sticks, so i go bad and get from my old PC one 512 stick @2100 speeds, stick that in and same problom. so i am thinking possible bad MOBO? i think this becase when i was waiting for my 2 gigs i used that 512 stick and maybe the speeds all fucked it all up or all 3 sticks happened to go bad at the same time, shitty timing. so what do i do? its not the OS, i mean i have redo it 3 times and taking my time the last 2 times, it used to only happen after i installed SP2, but know it is more random, weird though it did run stable befor sp2. i dont know what to do, i feel dumb and useless, is it time to seek professonal help?
pissed off wes
screen i am seeing with idea how to fix it....
http://help.lockergnome.com/lofiversion/index.php/t14879.html
http://www.computing.net/windows2000/wwwboard/forum/61315.html
http://www.computing.net/windowsnt/wwwboard/forum/22007.html
pissed off wes
