MassiveOverkill
- Jul 8, 2005
This time around I wanted to keep hacking up of the case to a bare minimum. I was able to get away with only having to cut the side rail, and slightly trimming the side panel tabs. I think it looks much cleaner than it's predecessor: http://www.hardforum.com/showthread.php?t=973995
Idle temps at 1.4V for each core are 31/38C and load reaches about 45/55C, with Prime95 running on one core and my X1800XT running RTHDRIBL on the other. I was tempted to redo or just remove my IHS, but as long as it's stable, I'm happy. Video card temps are 41C idle and 53C load with the core at 1.4V
Cutting the rail for the HE 120 radiator:
Fabricated support bracket:
Fit's without having to hack up the rest of the case:
