Massive overheating w/ E6600 and GeminII HS
5.0_Capri
I upgraded to an E6600 a few months back and as soon as I cut my system on it jumped from ~40* to over 60*. I thought I screwed up the thermal paste at first, so I took it all apart, re-applied it, then put it all back together, all to no avail, the processor still shoots to over 60* within 20 seconds in BIOS. I didn't have any fans on my GeminII at the time, though I had run it w/o fans here and there w/ a 3 ghz Pentium D and it never got above ~50*, so once again I thought I fudged up the thermal paste or didn't have the HS on tight enough. Tonight I redid everything, and am still having the same problem!
Do you guys think it's the processor? (Bought used on Amazon Marketplace) It literally goes from ~40* to ~65*ish in about 15-20 seconds while watching it in the BIOS.
I'm running an E6600 in a nVidia 680i LT mobo, Cooler Master GeminII HS w/ Arctic Silver 5 thermal paste and 2x 120mm Antec TriCool fans, 2x2gb OCZ PC-6400 RAM, BFG 8800 GT, HDD, DVD Burner, etc.
Your heatsink isn't making proper contact with the processor. See if the base of the cooler is resting on top of a coil box or a capacitor.
Are you pretty sure? I'm about ready to pull the trigger on an E8400, and if I do just to find out it was my HS I'll be PISSED!!!
Do you have any recommendations for a new heat sink? Something w/ the cooling power of the GeminII (the thought of two 120mm fans really puts my mind at ease) w/o the GIGANTIC size, and also something that I don't have to take the MOBO out every time I need to get to the CPU
Oh, btw, Thanks for the response!! Good to see somebody else that doesn't like to sleep =)
If the temp is jumping that fast not even under load, it kinda has to be that the HS isn't touching or is barely touching or the thermal paste is all jacked up or something. A jump that fast and large means heat sort of isn't leaving the CPU - you don't want to put any load on the CPU until you figure out the problem or you may just fry it. You may fry it without load too but thats less likely anyway.
You should use a small amount of paste - whatever the AS web site says for a quad core - and it should get smooshed down nicely when you apply the HS. When you do apply the HS try to do it all in one motion until it's clipped down - don't apply it, squash the paste then pick it up to check or anything like that.
In your case, I'd remove the HS, clean all paste off everything and then do what I just said not to do - apply a small amount, apply the HS and then remove it and check what happened with the small amount of paste. Once you fix it, clean again and apply in one motion.
Sleep? Thats what you do when the sun comes up!
I like how you think! Thanks for the suggestion, I'll rip it back down today when I finish up with my classes (and a brief nap, of course).
I'll let you guys know how it goes.
Yeah, it doesn't mean the processor is bad or the hsf is bad, the mounting is probably off a bit. I had one on my E2180 that I overclocked to 3GHz without problems with temps in the 40-50C range. It now keeps my father's AMD 6400+ from frying. Its not the best out there but it should certainly get your temps lower than what you are getting now.
My story: when I first got my XP120, my orientation had the long base of the XP120 resting on top of some capacitors. Flash games would work me up to 50'C. Finally decided to flip it around, all was good.
I'm having the same problem as you. Our set ups are close except I'm using the Gigabyte 965P-DS3 and Zalman CNPS9500. I'm overclocked to 3 Ghz on the CPU and my temps are 65C. I've lapped the heatsink bottom, reapplied the thermal grease and screwed the thing in as tight as i can it doesn't change one bit. I'm not overvolting it at all. It is an early part shows Revision B2 Stepping 6.
I've had no luck. Think I should jump to another CPU cooler? I changed the orientation from vertical to horizontal and it did nothing. I put a small dot of thermal paste on the CPU and put the HS back on, then took it off and it smeared a bit onto the HS. So I applied thermal paste correctly (thin layer across CPU) and put the HS back on, put the system back together and switched it on, just to have it jump to 71* in about 20 seconds.
What do you guys think, new heatsink? Could the CPU be too shallow on the top to allow a connection with the base of the HS?
I'm not clear what's going on with the thermal paste here. You did the 'spot' method, then removed the heatsink and spread the paste some more manually? I think it would be better to just put the heatsink down and leave it there.
"correctly" is NOT applying a thin layer across the CPU. See AS site for info:
http://www.arcticsilver.com/pdf/appinstruct/as5/ins_as5_intel_quad_wcap.pdf
you should be applying a bead across the CPU and then the HS should be squashing that into an oval. If you apply a bead like this and it's not squashed down into an oval when you apply and then remove the HS, or if you applied a small dot and all it did was smear some on the HS but not squash your dot down into a circle, your HS isn't making proper contact with your CPU.
My HS wasn't making contact w/ the processor, the bracket on the base of the HS wasn't tightened down....I'm a noob. Anyways, thanks for the help guys!
Great to hear that you figured it out.. I have 4 of those GeminII's and they are nothing short of awesome. They make great SYSTEM coolers!
