Need some expert help with MEA and Audigy FX card while using headphones. I know how to access the basic sound panels in Windows 10 and I tried selecting Headphones as main default and used the headphones/Front LR output jack on the FX card and it improved but some voices/effects sounds are still almost no volume. I use a Klipsch ICON SB1 sound bar + sub but it uses the HDMI signal from the GTX 1080 card and that works fine. Only issue is when using the FX Front LR Line out jack which is also labelled "headphones".
I'm thinking maybe the FX card is set to 5.1 and I need to set it to 2.1 but I can't seem to find the sound panel that will let me change that parameter.
What to do?
What to do?
