Skripka
- Feb 5, 2012
ME2 with all DLC is slightly longer than ME3. ME3 doesn't have the same amount of planet scanning or driving sequences the earlier games have. Despite the side quests being less interactive, there is far more dialog in the 3rd game. I wouldn't say that there are necessarily fewer missions, but the way they are allocated is certainly very different. Essentially you get about 5 missions in ME2. Do those and then you have 15+ available to do all at once. This game allocates 3-5 at a time and you can't go onto the next set until the main priority mission is done. Which you can do whenever you like, then then you can't do the other missions associated with that part of the story. If you fast track through the game, you can still get the "best" endings (a term I use very loosely) just by hitting mostly priority missions and a few others in a little over 20 hours. But to do everything will take about 40.
My best time for all missions completed in ME2 with no dialog skipping is 43 hours and 22 minutes. My first run through it complete was 49 hours and I average about 44-45 hours normally. This game I can do in about 41 hours on the first try. I suspect that I can complete it in as little as 38 or 37 hours in subsequent runs with some dialog skipping which puts it closer to the length of ME2 without DLC. With no DLC content, I could finish ME2 in 35 or 36 hours most likely. Lair of the Shadow Broker is at least 2 hours, Project overlord is another 2 hours, the Arrival is about an hour and a half to two hours, and Project Firewalker is about 30-45 minutes. For comparison, I can get 100% completion of ME1 in 32 hours and some change without DLC.
With ME2, with a save editor to free you from that annoying planet scanning for resources, I found the time needed to beat ME2 dropped in half or more. My 1st career, fairly completionist on ME3 took about 25hrs according to the game counter. ME1 about a similar time.
