Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I recently used a dremel to cut a hole for a 120 mm fan in the side of my aluminum coolermaster case. Looks great and I will be posting pics of it when I am finished putting a window in it. Anywho, I didint wear a mask and when I was finished I blew my nose and my snot was filled with black aluminum dust. I was wondering if anyone else has had this issue because I dont want Alztimers, should I be worried? btw if I die it will be honerable death. cool mod. The blue and silver combo looks awsome.
fill your sink with water and dip your head into it, than blow all the air out your nose..there's nothing you should be worried about..and i think breathing a little will help(not trying to make you kill yourself )
a mask would be a good idea ... though i wouldn't be worried about aluminum shavings causing "Alztimers" ... you'd probably remember why you were having trouble breathing
a mask and eye protection is really smart when you're working.
