March AMDness mobo help!
Black.Ice.
Hello All,
Newegg and a couple of other sites just started this promotion of a few PII CPUs combo'd with either a mobo or a GPU.
http://promotions.newegg.com/AMD/Ma.../promotions.newegg.com/AMD/March09/478x88.jpg
Im planning to get the PII 940 with one of the mobos but i'm caught in a conflict. Im planning on getting one of the 790GX chipset boards but Im not sure which one. Im debating between the Gigabyte GA-MA790GP-UD4H, Biostar TA790GX, and the MSI DKA790GX. However, leaning more towards the Gigabyte, since it's been getting pretty good egg reviews.
Anyone have any words of wisdom or experience with any of these combos?
Thanks Again
I'm using the MSI DKA790GX Platinum right now and haven't had any issues with it. It posts with the Phenom II but you will have to flash the BIOS to get it recognized, which was a pain at the time, but the MSI user forums help in that process.
i was going to go with ASUS M4A79 Deluxe ATX AMD Motherboard, but then though about it and will just put put more money and get an i7 setup so i wont have to upgrade for another 3 years or so.
In the past week I have literally purchased 3 of the GA-MA790GP-UD4H and love them. They went into different builds, and all three function and work perfectly.
Great boards, lots of options, OC like crazy, great quality. Love 'em.
Only one quirk i've found, the board's oboard RAID function does not like Adaptec controller cards AT ALL!
I am running a SCSI and SATA RAID setup, and no matter what I did, the RAID function would not work with an adaptec card plugged in. I tried different models. I do not have any other brands to test, but I tried it on all 3 boards and got the same results. I just went to all SATA instead, no more issues.
Of course, if you do not run SCSI drives, than it's a non-issue. But felt I should mention it anyway, due to the myriad of system setups around here.
All in all, i'd say the board is a winner, and I'd buy it again.
JMO.
