Mapped drive & error checking while transferring
cpaqf1
Hello everyone,
I just mapped a drive on my home network and was wondering if windows has anything to prevent errors while transferring files.
thanks in advance
FTP?
Or use one of those applications that can check the integrity of source and destination when finished.
Teracopy springs to mind
I mean, if I map a drive with regular windows folder&file sharing, does it have anything to prevent errors or do I have to use FTP ?
thanks
To be fair, unless you are shifting SERIOUS traffic on your internal lan, I doubt you'll have an issue.
If you are shifting serious traffic, setup VLANS and some QOS.
You can use FTP, and tell the client you use to use your mapped drive.
Do you have any reason to suspect you will need error checking?
I believe Robocopy can do some sort of hash or integrity check.
But no, nothing integrated in to Windows short of the command-line FTP
