bigstusexy
- Jan 28, 2002
Hi all, I'm really getting fustrated with this, I REALLY hope I don't have to send my card off (how long is the warrenty anyway)
MY BBA 9800 pro 256 (brough from teh egg) is acting up, I play a game like a halo and the frames bleh but thats a different story, the system will crash a lot when playing that game, not sure if when i play another game because I don't play too many other games right now. This has happened with a different computer too, I have just inherited a new computer and dropped in my card in it and its still doing the same thing I'm running the cat 5.2s. What over info do you want? I have turned off recover VPU, now this use to work a bit, I'd play and the game would freeze and then sometimes it would recover, after that point it would work fine, now it either doesn't recover or the problem happens after the recover. Also since I can get back into action quickly I've been totally fustratred by the fact that when I get back into the game quickly it will do it frequently again.
Soon I'm thinking of redoing windows but the installation is pretty fresh.
HELP! What do you think it is? voltages are ok says MBM, can't see the temp on the card because its not the XT (although I believe its an XT core) everything is stock.
