Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
no, it's just an error, they didn't fully program the SPD is most likely the case. you can always check the stick itself, the sticker will tell you when it was made
