Man, I'm at a loss...
mikepennyd
Hello! I have a desperate problem with my system
and would appreciate any help that you can
provide. (System Specs are below).
I have a homebuilt computer that has been having some
intermitten boot problems. Allow me to explain. When I
start my computer up in the morning for the first
time, or, if I reboot the computer after I have been
using it, my computer will simply shut down. For
example, when I hit the power button, the computer
will go through the bios loading but before it starts
loading the operating system it will shut completely
off. Othertimes, the computer will boot up normally,
but when I restart it will shut off before it loads
the operating system.
My computer is about 16 months old. I have noticed
this first happened about 8 months ago where it did
this at a rate of once per week. The situation has
steadily worsened since then. Now it is at the point
where it needs 3-4 attempts to get it to boot phase
(not good...).
I also noticed that there is an occassional bios
"alarm" of some sort that goes off about every 2-3
weeks or so. It literally sounds like an siren,
continuously wailing until I shut my computer off.
Please note that the alarm sound doesn't seem to
correlate with the occurance of any boot problems. I
used a program that came with the motherboard to
monitor the fan speeds of the CPU and system fans as
well as the voltage. They all said that no problems
existed. I also watched the fans myself and there
seems to be no problem with their operation.
I have never overclocked or made any voltage changes
to the system.
I was told by a friend that the problem was likely
memory related. At his request, I ran a program called
"memtest86" several times (7 passes) and no problems
were recorded. However, I did notice that the bios
"alarm" sound (mentioned above) went off many times
during the early going of the test. (Which, is odd,
since memtest86 recorded no errors. I'm not sure if
they are related).
Many thanks to anyone who can give me a hand! I'll be
happy to answer any questions you have for me. I am at
a loss of what to do.
Specs: Abit IS7-E, 2x512mb Geil RAM (3200), P4 2.8ghz,
400w foxconn PSU, 9800pro
one of the first things I would try (if you havent already reset the cmos) would be disconnecting all your fans, hard drive, cdrom, etc. so the only thing being supplied power is the motherboard and vidcard. Try booting the system a few times and see if its more reliable. I cannot vouch for the reliability of the foxconn power supply.
That would be my first step if I were you.
Does it make a low-high siren sound? I have only worked on intel based abit boards, never owned one so I am certain there are many more experienced persons here that would know any real quirks that arent covered in any manual.
The first thing I would do is remove the cpu heat sink, wipe off the old thermal paste and put a new layer on.
If you have a thermal pad, remove the old pad with 99% alcohol and put on white thermal paste ($3 from Radio Shack). (I only use white thermal paste, I no longer use Aluminium based pastes, like Artc Silver).
