Male Angle Dont Understnad?
You put the tubing in it, then tighten down the nut. It's one of the most secure tubing connectors you can use.
Koolance VLV-M10LC 10mm (3/8") ID Quick-Disconnect Shutoff Valve - Male angle connection with compression fitting (will fit any Koolance female shutoff valve).
After a brief twist, the quick-disconnect nozzles will separate. Liquid on both sides will be automatically obstructed with only 1-2mL freed. Nozzles are chrome-plated brass.
but how come there is no compression on the other side for the other tubing? and whats that thing in it?
I really want to order it tommorow but dont know what it used for and will it work as a 90 trangle for tubing from both sites and i dont know why there is no compressing on the second one.
its not what you are looking for. the part with the red o-ring is for a quick disconnect female. you need a 90 with compresion fittings on both sides (which i don't believe koolance makes), or a regular 90 for use with hose clamps link to cheapy
I bought 4 of them what should I do!? Yes I got them today! Yes I am Blonde! what would you guys recommend me doing with them?
I just bought the female angle Actually I think it would look good since now I have two covers that can go anyway instead of one!
