Mako 5.0 released
ChadD
Haven't tested it yet. But new 5.0 Mako out with an option for its own frame gen model. Meaning lossless frame gen is not required. Though you can use LSFG.
https://github.com/eugeniosegala/MAKO/releases/tag/plugin-v5.0.0
Pick a Frame Generation model: Choose MAKO FG, LSFG Quality or LSFG Performance per profile and power mode. Switching between MAKO FG and LSFG needs a restart; LSFG Quality and Performance switch live. LSFG and LS1 still require your own Lossless Scaling installation.
So lossless.dll or lsfg-vk.dll aren't required? Or is an actual install of lsfg-vk not required? The instructions aren't very clear.
You can use lossless with lossless.dll. or you cannuse makos own frame gen algorthem. If you dont have lossless the option greys out.
From reading a few comments on their discord it isnt on par with lossless yet. But its a first release.
There is a new drop down for frame gen method. Mako FG, lsfg quality, lsfg performance are the options.
