G'day all,
I've been looking around at coolers for 4870s and have just been thinking, all these coolers are is a plate to get heat off the chipset, copper heatpipes (optional) to get heat away from the card, then aluminium or copper plates to disperse the heat and maybe a bracket for a fan.
Sounds pretty simple to me, has anyone tried making one themselves?
Its possible it may end up more expensive, but I have access to a lathe to make spacers, mill to make any block type things, tap sets for screws, grinders and relatively cheap aluminium (plates at least, haven't checked rods) so was thinking of giving making a cooler a bash. It means I could make something that takes the air sucked in from outside the case by one fan and then exhausted by another case fan, something most coolers can't do (they usually suck hot air from inside the case and often just blow it back into the case again).
Any thoughts?
Any thoughts?
